74 hood
Date: 07/03/2017 03:46 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
parts needed
Date: 02/20/2017 07:58 am
Date: 08/06/2021 02:23 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Date: 01/21/2023 04:19 pm
  • Online today: 584
  • Guests: 404
  • Total: 404
Pinto V8 Clutch
Started by Pintogary, March 19, 2004, 10:41:55 AM
lyndensv8
hello  i use a mustang 2 bell  and reballanced flywheel and stock pinto clutch cable.  works great  good luck
Pintogary
I have a '74 Pinto with a 289 V8, toploader 4 speed and Lakewood bell housing.  I have not been able to find a clutch linkage setup to work sufficiently.  Currently I am using a Wildwood hydraulic setup.  It works, but the pull angle is too great causing binding, friction... The main problem seems to be a lack of space to put it.  The tunnel is too close to the clutch fork. No room for modification due to accel pedal on other side.  I am curious how others have solved this problem.
PINTOGARY
'74 Pinto 289V8 HotRod
