1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
78 windshield trim
Date: 02/01/2020 08:46 am
Date: 06/24/2020 06:12 am
Date: 04/30/2023 04:31 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 06/07/2018 01:45 am
Pinto Watch
Date: 06/22/2019 07:16 pm
  • Online today: 489
  • Guests: 270
  • Total: 270
Driveshaft distributor?
Started by TPS24, February 11, 2007, 01:01:42 AM
I bought my 73 from a friend of mine.  He used an aluminum driveshaft off a Aerostar van that he paid $15 for from the local u-pull it.  The tube is larger in diameter than the stock Pinto driveshaft but that should not mater unless your car is super low.  One of the u-joint ends is pressed in via some splines.  All you need to do is cut to length and press the end back in.  He had it welded to be sure it did not move.  I am not sure if he had it balanced after it was done but so far I have not noticed any vibration.
TPS24
Hey Guys
I race a 76 pinto chassis with a 97 probe body in the Texas Pro sedan series, The Fastest 4 cylinders in Texas. Our race director favors VW drivers so us Ford drivers are trying to play catch up. To lower rotational mass I want to get a lightweight driveshaft. Does anyone know of a lightweight driveshaft available for a 76 pinto or one of its length?
Thanks
Josh
