Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 08/13/2021 10:39 am
Date: 11/11/2019 04:49 pm
Date: 10/25/2019 04:05 pm
Date: 08/20/2017 01:34 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
77 pinto
Date: 08/22/2017 06:31 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
  • Online today: 548
  • Guests: 457
  • Total: 457
HELP Please!!!
Started by pop67w, February 06, 2007, 03:28:19 PM
little thunder
I tied my 75 together with 2x3 box, went flat to the front frame staight to the back. No floor mods required although it,s a little overkill on size, run a 2x2 piece across between to tie those together made it real stiff. Car launches straight and flat but it's a 2.3 motor. See pics in your racer 75 Pinto  good luck
                                                     little thunder
The BEST way is a well built full roll-cage.
Make sure you build it in accordance with any rules that my apply at your track.
pop67w
I am in need of help on how to tie a sub frame in on a 1971 Pinto.It is going to be used for dragstrip racing.Or does it need to be tied in???  I was told if I did not tie it.It will not go down the strip stright.Any help would be great.I am putting in a 302 in it.Thanks.            William.
