Date: 08/08/2018 12:26 pm
72 pinto
Date: 06/23/2016 12:40 pm
Date: 12/20/2016 10:47 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
Date: 02/22/2017 01:58 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Date: 04/07/2021 06:12 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
  • Online today: 489
  • Guests: 351
  • Total: 351
Dash removal..please help me quick!
Started by orangerunabout, March 08, 2004, 07:07:38 PM
You pull the dash pad ,cluster &, Glove box. Disconnect the controls from the box. There's a bracket on the dash to the heater box. you remove the blower before the box. then there's 4 bolts holding the box to the firewall. It should slide out and down into the passenger footwell.
The standard heater should come out the same way except that the blower will stay attached
I just replaced my blower motor , trust me you'll need to put more than a few quarters into the curse jar  ???LOL
wagonmaster
Make sure you get all the ducting from the AC/heater box to the dash assembly as well as the control assembly and consolette.
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
orangerunabout
thanks guys, im going to go and grab it tomorrow. its hard to find an a/c equipped early pinto.
Check out the internets only Turbo Pinto forum
www.planetboost.com/pinto
wagonmaster
The dash assembly is held in place by several screws around the perimeter of the dash. The screws below the windshield are hidden by the windshield weatherstrip. If you cut the lower part of the weatherstrip away, it will make the job much easier. You will also have to drop the steering column and unbolt the pedal bracket and center support bracket. They actually come out much easier than I thought they would. The dash pad does not need to be removed when yanking the whole unit. I yanked one that had both AC and the Sports Gauge package to use in my panel.
Brien - wagonmaster
'85 LTD LX
Scott Hamilton
I have taken out the interior air handler box without removing the dash, if I remember correctly you will need to remove one 'attaching' brace that hold the dash assemby in place, it's been 5 years since...
I know you can remove the air handler without removing the dash completely, ....
Hope this helps,
orangerunabout
i dont want the dash, i just want the a/c box.
it is a junk car, destroying things is not a concern at all.
 None of my books give me that info, sorry. If you are taking it from a junk car you could cut it up pretty good and get it out, then look for signs of how to actually remove the dash. ( best guess )
 ( Plasma cutter)  :o
Im looking in my books........
orangerunabout
thanks a lot, please let me know.
it has to come out because the previous owner of my car removed mine. If it doesn't come out, how am i suppsoed to be able to get the a/c box out?
Ok, I was thinking dash pad. I have never taken apart the whole dash assy. I dont even know if if all comes apart. I will look in my books.
orangerunabout
edit
im not talkling about the dash pad, im talking about the whole dash assembly thing.
orangerunabout
so youre saying theres no point in removing the dash?
it looks pretty big to me, how would i get it out?
You will not be able to access anything by taking the dash off. The studs are about dead center of the dash.
orangerunabout
i took off the glovebox and instrument cluster today when i was getting some other things and ran out of time to finish.
are the studs near the passenger side or the engine side of the dash?
the a/c box easy to remove once the dash is gone, meaning is it just bolted in there basically?
There should be about 5/6 studs on the under side of the dash with nuts on them. You will need to remove the glove box to get to the passanger side. As far as the drivers side  ( I think) you need to go in thru the spedo cluster area. drop the cluster out and I think you will have enough room. any one else want to add??
orangerunabout
I found a pinto in the local yard, a 72 model to be exact, with a/c and a 2.0. I need to remove the a/c box from it but do not know how to get to it. I need to know how to remove the dash from the car and then how to remove the a/c box. If you only know part of the answer, please post it. thanks!
