1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Electrical
Date: 03/29/2017 11:37 am
Date: 02/25/2017 08:45 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 02/18/2017 04:41 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
Date: 01/23/2023 02:22 pm
Crane Cam
Date: 02/26/2018 07:50 am
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
  • Online today: 502
  • Guests: 395
  • Total: 395
Still needing a '72-'73 (71?) pinto GRILLE. Again.
Started by swinklksd, February 03, 2007, 01:21:16 AM
dotts9681
Hi, I just joined and posted about having Pinto Parts and I think I saw some grills in boxes. Do you know what parts number you need?
Tom Dotts
Dotts Motor Company
Bipper
To repair plastic grills, use a two part epoxy specifically for plastic. Your local hardware store
should have it, not the home depot type store. Let the epoxy squish out a little from the
repaired areas. After it dries it will be so hard that you will be able to file the repair and sand it
smooth. After painting you will not be able to see where the repair has been made. I have
repaired plastic grills on Pintos and Torinos and it works great.
71 Sedan, stock
72 Pangra
73 Runabout, 2L turbo propane
swinklksd
   I have a 1972 with a broken grille. What other year models use the same grille? Also, what kind of glue can I use to put my old one back together? Thanks.
