Date: 08/30/2021 03:20 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
Date: 10/10/2019 09:42 pm
79 pinto small parts
Date: 04/24/2019 03:16 pm
Wheel cap
Date: 04/25/2022 11:21 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
Date: 04/15/2017 05:14 pm
  • Online today: 481
  • Guests: 254
  • Total: 254
High Idle?
Started by 2point3turbo, January 30, 2007, 03:02:06 PM
2point3turbo
I have the idle screw all the way down and the cable is fine. I cleaned out the IAC and put it back on and it ran fine. When I started it back up again the idle went back up. I also have to unplug the battery cable every time or it will drain the battery so I dont know if that could cause the ECU some confusion as well. Also want to state that I only hooked up the wires noted on all info I found on the swap about constant power to the ECU but who knows, I might have some of the Pinto wiring running all the time when it should be key switched.
If you are running a stock 2.3 EFI T/B, there is an idle adjustment screw on it. If that won't bring it down, check for a bind in the cable or linkage.
2point3turbo
II have the car running better then ever but it wont idle down. I dont have a RPM gauge but it sounds to be idling at around 1300 or so. I have tried a few steps but cant get it to idle down. Any suggestions?  You think I might know a thing or two after all my posts but I am slowwwwww!!! Thanks guys!
