KYB shocks
Date: 02/08/2017 07:09 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
oldskool787
Date: 02/12/2017 12:42 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Date: 04/21/2017 02:03 pm
Date: 12/15/2018 02:21 am
Date: 10/10/2019 10:02 pm
Date: 04/08/2018 05:47 pm
  • Online today: 292
  • Guests: 276
  • Total: 276
Help i can't get my Pinto to start and run in the cold weather
Started by runabout74, January 25, 2007, 01:56:10 PM
mark78
I do not consider myself to be an expert, but my car was difficult to start too and choke never worked.
When I got my carburetor cleaned and tuned, things got much better.
my pinto lives in Greece since 1973...
Runabout74,
        I am not now nor have I ever had a ford with a good choke. I always remove or disable them in the open position. Properly tune the car and use the accelerator squirt to start the car, keep it running for a few secs and it will idle like a champ till warm. They don't open right they fowl the plugs and so on and so on. If that is the problem do yourself a favor and pull that thing out by the roots.
        No-Choke_Horse
        #226
is this a cold weather only thing?... if so you may have a problem with the choke not working properly.
can you keep it running by holding the gas pedal down a bit?
could you have water in your gas?
Fords are known for being "cold natured", not idling to well until they've run a few minutes.
runabout74
 ??? i need help to get my pinto to run. when i start it wont stay running it sputters and spits. can anyone tell me what the problem is?
