76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 02/28/2024 02:07 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 07/04/2022 07:55 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
  • Online today: 802
  • Guests: 142
  • Total: 142
8" questions
Started by wingless01, January 24, 2007, 09:58:09 PM
turbo toy
I have been running an 8" with a spool and 4.62 gears in my Pinto for a year and a half now. I'm also running a T5 and 28 X 11.5 X  15 MT ET Streets..I love it and wouldn't change for anything.
  ;D  :)  ::)  :-\  :swirl:  :surprised:
"....you can almost forget trying to push it and turn the steering wheel...."
;)  Does that mean that ALL spools are bad?  ;)  Or only those who are strong as an ox should push them ?  ;)  Or that if you are going to turn corners that you shouldn't have one?  ;)
OMG I'm being soooo negative!!!   ;) ;) ;) ;)   :peace:
I've actually used a mini spool on the street with good success. ( disclaimer ) never in the rain or when wet.
The under 5 mph turning is a bear ( read chirp,chirp, chirp ) and you can almost forget trying to push it and turn the steering wheel. :)
wingless01
CHEAPRACER
All my stock rear brake parts, including the shields, bolted right up to my 8inch. And Blacksheep is right, I've used a spool on the street and just a water puddle was enough to send you into a spin around a corner especially when the trans went into second gear.
Blacksheep22
I wouldnt recommend running a full lock on a street car. Rain wouldnt be that bad but turning on dry asphalt you would be asking to break an axel. If it doesnt break it will hop so bad turning in a parking spot that it will drive you nuts.
71 Pinto Mini-Stock 1994 Track Champion
72 Pinto all original 63000
73 Pinto Wagon 2.0  4 Speed 8inch
wingless01
i have an 8" with 4.11 gears and a spool left over from when i raced mini stocks and now i am building a street pinto and i was thinking of putting it in.  I am going to be putting some pretty big meats on the back of the car and i am worried about how it will turn especially in the rain.  The lockers for the 8" are a little more than i want to spend but i will if i have to.  I really want to stay away from the limited slip too.  Also will the brake shields, drums, everthing from the outer edge of the axle fit off of my 7.5?
