Date: 04/15/2017 05:14 pm
Date: 03/23/2018 09:23 pm
Date: 06/24/2020 06:12 am
74 hood
Date: 07/03/2017 03:46 pm
Date: 08/03/2017 07:40 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 04/30/2023 04:31 pm
Date: 03/07/2017 07:03 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
  • Online today: 445
  • Guests: 209
  • Total: 209
72 Pinto Wagon.....What stock V8 exhaust manifolds will work?
Started by gofast2007, January 09, 2007, 12:24:35 PM
vonkysmeed
I used headers off a Mountaineer with a 302.  I did not want to cut the fenders and with the 351 it was dificult.  Here are a few shots
now my exhaust does go under my cross member, but does not seem to be a problem at this time.
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
GoFast2007,
Pic#1>>> Here is a pic of what will work on the left side. Also here is the number you can call to try to get one(courtesy of GearHead440) B&M Engine Supply in Texas 1-877-844-9832. Or call the junkyards and ask for a left side Mustang II v8 manifold.
Pic#2>>> Here is the right side manifold I used on my car. I think this is a fairly common manifold used on Ford v8's cause it had the choke heater tube cast into it. The one pictured is off of a 74 bronco. I ground the tube cast off of it to make room for clearence and it made it fine.
Somebody put some information on this site about the time I was doing my conversion. If memory serves me right they showed a picture of two manifolds, where he got them and their part number. I don't have time now but I will look later. They were aftermarket, I would have bought some if I did not already have some.
This is a darn good question.
I put a 5.0/AOD into a MII I used factory MII manifolds. You can't use the "shorty" headers as the D/S exits into the steering column.
V6 Cat
I'd sure like to know also. I have a '76 Bobcat that I would like to put a 5.0 and an AOD in.  :text_yb_please:
james_okeefe
 :fastcar:I have a 302 in my 77 wagon and I was able to clear factory exhaust manifold from the smallest Ford V-8 engine  could be a 260 but not shure. I'm   shure someone on this site knows.
gofast2007
I'm planning a V8 Swap into my 1972 Pinto Wagon (302/T-5) and I would like to know what stock exhaust manifolds will work? Also what is the best engine mounting application?
