Date: 06/25/2021 12:59 am
73 Runabout
Date: 11/20/2017 03:19 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 08/26/2018 06:23 pm
pro stock front end
Date: 06/28/2019 07:43 pm
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Date: 10/03/2018 10:46 pm
  • Online today: 489
  • Guests: 121
  • Total: 121
302 headers?
Started by flatlander, February 29, 2004, 08:43:02 AM
flatlander
I'd like to see pics of the Mustang II headers with modifications (in car).  The links don't seem to work.
I've got to see pics of this car... sounds interesting.
Frank
WWW.PintoWorks.com
flatlander
I'm thinking of just going with baffled zoomies right out the hood
PintoBro
Quote from: V8pinto_306_n2o on January 16, 2005, 06:45:01 PM
Hey Pintobro,
Nice video.  I can't believe those things fit.  Do you remember the part number if the headers?  I have the Hookers with two tubes on each side out the fender wells and I don't like them.  Lots of power but they never ever seal up.
Lemme know.
Shane
306 N2O Pinto
I don't remember the part # for the headers, but if you get a set for a 74 or 75 Mustang II, with a little bending, you should be good to go. We tried installing them with the motor and tranny in, from the top & bottom, and found that the only way to get both of them in is by bolting them on with the motor and tranny out of the car, and installing the whole thing at once. Also, if you don't want to pull the motor and tranny out in the future to replace the starter, go with a mini high torque starter (the one with the selinoid on the starter). If you want to retain the original selinoid, just make a jumper from the battery post to the starter terminal on the selinoid.
Pintobro
71 Pinto 306 10.0:1 351w heads
Comp Cams: .554/.558 lift .294/.306 duration
Torquer II Intake - Holley 750 HP
Sepanek's Racing Transmissions C4 (Full Manual)
8" rear (4.62 spooled)
71ss351
I am going to use the same headers on my 71 351 setup but I am going to have my buddy at the muffler shop weld them up for me because ounce they are on they are staying on when I pull the motor out they will stay in.
71 Pinto
351 Interceptor w/ comp 274 cam
C-5 Transmission
7.5 rear end with 3.73 posi trac.
V8pinto_306_n2o
Hey Pintobro,
Lemme know.
Shane
306 N2O Pinto
PintoBro
Quote from: dick1172762 on September 05, 2004, 04:26:05 PM
Wheres that web site? I remember the old one and look foward to the new one. Did you move? Tricky Dick
Are you referring to my website? It's at the same place, on the computer here at the apartment. It was off line when the DSL modem and router took a lightning hit. The addy is still http://avs.epix.net/geb
As for the headers, click on the link for my videos. There's a video showing the best and probably the only way to install Hooker Mustang II V8 headers.
Pintobro
PintoBro
I used Mustang II headers, and they hug the motor and go back normally. In another week or so, I should have my website back up, and I'll post a link to it when its up. I have a ton of photos, and a few videos as well.
Pintobro
Sly Willy
Hooker has em..or at least had them for a pinto.
flatlander
Howdy,  I got a race orange '75 hatch with a 302 and cast heads.  The cars got a macpherson strut front end with the close ratio rack & pinion out of a cobra II.  I'm ltrying to find out if there's a header kit for this sort of thing.
btw the car has well made aluminum sheet inner fender walls that I don't want to cut (incase some route around the spring or somthing weird)
thanks for the help!
