Date: 07/13/2018 02:21 pm
Date: 07/30/2018 04:32 pm
Date: 07/08/2022 11:51 pm
Electrical
Date: 03/29/2017 11:37 am
Date: 03/06/2017 01:19 am
Date: 08/22/2017 09:21 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 09/12/2018 12:33 pm
  • Online today: 450
  • Guests: 361
  • Total: 361
v8 swap
Started by dave1957, January 08, 2007, 10:26:55 AM
71hotrodpinto
Hi all,
This pan is expensive as all getout (plus you need a new pickup) but it fits without cutting.
http://cgi.ebay.com/ebaymotors/Milodon-Street-Strip-Oil-Pan-30926-New-In-Box-Ford_W0QQitemZ220054524008QQihZ012QQcategoryZ38657QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Now i lowered the rack in my car so i could get the engine lower ( i know about the geometry issue). However the pan still clears front to back as it should. With the rack still in the stock location, it will clear although the engine still sits too high in my opinion wether or not you use the mustang II pan or the milodon pan.
You will need a new front cover and alternator setup to mate with the front sump pan also.
any more questions feel free to ask.  :idea:
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
dave1957
no it is not the whole engine I have the turbo, intake,,,, wiring harness computer, vaf,intercooler , and disc brake rearened w/3.55 gears........david
1979 bobcat
1974 red stinkbug
Is that the whole engine from a SVO?
dave1957
thank you very much for the info  :exclamation:  iknow where to get a ford granada the same year, problem solved anyone interested in a turbo setup from a 86 svo ?
1979 bobcat
1974 red stinkbug
hoots
It came from a 1980 Versailes
dave1957
mine is a 79 with a 4 banger  what year of lincoln was your pan? thx dave
1979 bobcat
1974 red stinkbug
DAVE1957,
     I had a pan made using a 302 blank core stamping. Pictured below is an old stock 65 Mustang pan and my pan made from a blank. I did not see what year Pinto you are working with. Did it have a v6??
hoots
I got my 302 from a Lincoln Versailles, the pan barely clears the front sway, but when I jack the car up and take the load off the tires it does hit. I going to 'notch' the front of the pan this winter so when I get airborn there won't be any problems. :hypno:
james_okeefe
 :fastcar:I found the mustang II pan on ebay in the pinto section  even so I had to drop my front swaybar 1 inch to fit it  Good luck
dave1957
the ford dealer told me the pan is no longer made Would you know of an aftermarket one that would work?
1979 bobcat
1974 red stinkbug
the pan is easier than the motormounts so I'm told...
Are you looking for a salvage pan or new?
Frank
www.PintoWorks.com
prostang92
none thati m aware tried eraly mustang and no dice, needs to be modified
why is everybody always picking on me???
dave1957
finding a mustangII pan is next to impossible Is there a front sump pan that might work?
1979 bobcat
1974 red stinkbug
