1978 pinto grill
Date: 07/24/2018 02:18 pm
Date: 08/16/2018 08:54 am
Date: 05/19/2018 04:56 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 07/17/2018 09:49 pm
Date: 08/01/2023 06:53 pm
Date: 03/18/2020 01:30 am
Date: 02/04/2018 08:26 am
Date: 04/07/2021 06:12 pm
  • Online today: 447
  • Guests: 207
  • Total: 207
Holly 390 4 bbl carb
Started by Pinto_Guy, February 29, 2004, 12:17:32 AM
Not sure what it comes on stock but I will check. I have used the 390 carb before and those work real good also. The 390 I used was off a 1970 360 truck engine and was a 2 bbl carb. I rebuilt it and used the same jetting. Either carb you will need an adapter plate. The 2300 and 390 have a wider bolt pattern than the 5200 webber/autolite carb.
dyceman
TurboPinto72, is the 500 cfm a stock carb? If so, what does it come on? If not, where do I get one? I'm not real happy with my stock 2 barrel on my 77, so I'm looking to improve.
John
73 Pinto - "Land Rocket"
Pinto_Guy
I have no idea what the number for the carb is. I will see if the guy still has it. He was going to use it on a V-Max motorcycle but it was not big enough :o
wagonmaster
what is the List number on your 390 Holley carb and would you be interested in selling if you do not use?
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
 Yes, a real good choice for about anything you will do with that engine.
Pinto_Guy
Quote from: turbopinto72 on February 29, 2004, 03:32:16 PM
The 500 cfm 2 barrel is one of the best carbs for our engines. I have had real good luck with them and found no need to ever go with a 4 barrel carb.
Thanks for the info! My car is pretty much stock right now. I am going to be putting a header and removing some of the smog stuff. Is the 500 a good choice for this?
wagonmaster
If you don't use it, I'd be interested for my 2.8L V6.
Brien - wagonmaster
'85 LTD LX
Pinto_Guy
Anyone try one on the 2.3? I can pick one up pretty cheap and was wondeing if it would be a good replacement for the 2 bbl.
