SVO SWAP
Date: 03/15/2018 03:12 am
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 09/15/2019 12:28 pm
Date: 07/13/2018 02:21 pm
Date: 03/06/2017 01:24 am
Date: 03/25/2019 09:02 pm
Date: 01/12/2019 10:19 am
  • Online today: 536
  • Guests: 334
  • Total: 334
Fuel line question
Started by Farmboy, December 12, 2006, 09:19:24 AM
Hey Farmboy,
Yes!!! I like that you DUMPED the 2.3 for the 2.0.
Farmboy
  What would be the best new carb to put on the little beast, to get a litte more umph
74 Pinto Wagon
71 Runabout (parts car)
Farmboy
Quote from: Pintony on December 12, 2006, 11:37:52 PM
RACE ENGINES DO NOT USE HYDRAULIC LIFTERS ;D   quote]I'm a little confused, does this pertaine to me ???
74 Pinto Wagon
Farmboy
  Pintony, I just took a rubber hose shoved a bolt in and sealed off the smaller of the 2 fuel lines, the other fuel line goes to the fuel pump.
  Motor mounts, I cut them out of a donor car that the 2.0 came out of, set the motor in lined every thing up, and welded them in.
74 Pinto Wagon
Hey farmboy,
You say you took the 2.3 out and installed a 2.0??
There is no provision on a 2.0 Fuel Pump for 2 lines..
What did you have to do to make the 2.0 work??
Motor mounts?
Farmboy
  73pintogeek,  your right, 2 lines to the fuel pump, most of the time my mind goes alot faster than my hunt and peck typing abilities
74 Pinto Wagon
73pintogeek
Hey Farmboy,
I`m a little confused...the two fuel line`s should go to the fuel pump...not the carb...one supply... one return line...and the vent to the canister
A bad day workin` on my Pinto is better than a good day at work!
Farmboy
  there are 3 lines going to the gas tank, 2 to the carb and 1 to the charcoal canaster. The vent line was still hooked up. The fuel pump is putting out 5+ pounds of pressure and not bleeding back. I took off the other fuel line that I had blocked off and the same as before, it ran great till it got warm then ran really bad with no power. I guess the next step is to buy a rebuilt carb. It will cost the same as having a guy dip the old one and rebuilding it as to have one shipped to my NAPA dealer.
  Any more suggestion would be appreacted, My wife aint getting any happier but after 28 years of marrige, Oh Well ;D
74 Pinto Wagon
Farmboy
  Alright guys, something new to try, Frank, I know its not the choke closeing, but thanks for the input.
  You guys are the best :lol:
74 Pinto Wagon
Blacksheep22
Pintony is right, it is the vent line and normally hooked up to a charcoal canister. If nothing else just unplug it even if you dont hook it to anything. If you are worried about dust or dirt stick an inline fuel filter in the end of it.
71 Pinto Mini-Stock 1994 Track Champion
72 Pinto all original 63000
73 Pinto Wagon 2.0  4 Speed 8inch
All my stock 2.3's have 3 lines to the tank.
One fuel feed, one fuel return, and one vent.
Two of the lines come out of the sending unit in the lower front of the tank.
The vent is on the top of the tank and the line for it runs to the char. can. in the left front of the car.
Hello Farmboy,
Unplug the line!!! That is where the fuel tank gets it's air.
I did that once and it smashed my tank like a pancake.
I know its kinda simple but make sure the choke isnt being sucked shut ....Just had that problem with my falcon... Holley webber was starting and warming up nice...but it was puking afterwards...
Best of luck
Frank
Farmboy
  On my 74 wagon there are 2 fuel lines running fron the gas tank, it had a 2.3 in it but I put a 2.0 out of a 71. My question is the carb out of the 2.0 only takes 1 line. I have blocked the other smaller line off. Is that the correct thing to do ??  My car runs great when it is cold but as soon as it warms up it has no power to even get up a slight upgrade to get out of the driveway.
  I have put on a rebuilt dist., the compression is running at 130 on all cylinders, no vacume leaks, the decel valve has a new diaphram in it. new coil, plugs and wires, cap and rotar, new clutch and throw-out berring.
  I'm going nuts trying to figgure this one out. Any suggestions
74 Pinto Wagon
