Date: 10/10/2019 10:02 pm
Date: 12/15/2018 02:21 am
1973 Pangra
Date: 01/06/2015 02:19 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 09/01/2017 07:52 am
Date: 11/04/2018 02:34 am
Sunroof shade
Date: 06/19/2019 01:33 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
Date: 08/27/2018 11:11 am
  • Online today: 452
  • Guests: 324
  • Total: 324
upper a arm ?'s
Started by pinto_351, February 19, 2004, 03:19:19 PM
straw boss
Quote from: Glassman on February 28, 2004, 08:45:26 AM
thw sway bar link mount on the drivers side lower arm broke off. Im searching for one of those.
If you can't find one locally, let me know.
Quote from: 78pinto on February 20, 2004, 10:40:53 AM
my tubulars are sitting right beside me and it is 5 inches center to center.
Are they shiney?
Just for fun I checked my flat black arms and they are at 5".
Some of the problems I had were rusted bolts. I had to cut off one of the bolts to the frame on the upper drivers side. I had to cut off a shock bolt on a lower arm and thw sway bar link mount on the drivers side lower arm broke off. Im searching for one of those.
Have fun. ;)
yup, thats what i thought you meant....5 inches is correct.
pinto_351
i meant where they bolt to the frame
brad
did you mean the holes where they bolt to the frame or how wide the a arm is where the bushings go in.
pinto_351
thanks theres a guy selling some tubular arms off his race car and they look like they will fit a pinto so i emailed him and asked about them and all i need to know was the center to center measurements from both before i bought them.  thanks
pinto_351
can any one tell me the center to center measurement of the cross shaft mounting holes for a pinto upper arm.
Brad
