1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
looking for parts
Date: 06/19/2020 02:32 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Date: 02/18/2017 05:52 pm
  • Online today: 563
V8 swap ignition module
Started by hoots, February 18, 2004, 08:46:01 PM
gpinto2
I had the same problem with mine,tried 2 different stock modules,it would run about a week then quit working,so I switched over to a MSD-6AL and it solved the problem,it's been running on that for 4 years now.
1972 Pinto 410,C-4
dyceman
Ford ignition modules (those of the 4" sq variety made of aluminum) arethe same for 4cyl, V-6, I-6, and V-8 applications. The way to identify the module you need for your application is to look at the plastic grommet on the side of the module (where the harness comes out) in the car/truck that your engine came from. Most are blue. If the donor car's module matchs the stock one in your car, then getting anew module would be appropriate. I can't recall what all the color possibilities where, but Iam sure there was a white, brown,blue, and I believe yellow. Hopefully the donor car is still accesable so you can check it's module. If not, go the your local parts store and have them look one up for the donor car and check the grommet color.  ;D
73 Pinto - "Land Rocket"
pinto_351
mine ran on the original v-6 one.  Maybe yours is just getting weak.  try to get a new one.  they are not too expensive.  Get one from a pick up truck.
hoots
Ok you swappers, what ignition module did you use. I left the original one in and do have spark but it won't fire. Any pointers would be appreciated.
