Date: 08/06/2021 02:23 pm
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Parts Parts Parts
Date: 09/08/2018 03:13 pm
Date: 02/18/2017 04:47 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Date: 06/07/2018 01:45 am
  • Online today: 481
  • Guests: 84
  • Total: 84
Chasis Strengthening
Started by orangerunabout, February 15, 2004, 01:04:18 PM
Just a shot in the dark, but you could use subframe connectors, and who says a cage HAS to go all the way to the roof? could you do a half cage? build it to just below window level? put the upright hoop right behind the front seats only as high as the window. them just build the rest like any other 4point cage?
orangerunabout
I have a 71 runabout with a 2.3 turbo in it. I am planning around 300hp without nitrous and then around 400+ on the spray. I plan to run subframe connectors to stiffen it up a little bit. This car is being built to be a sleeper and a cage definitly gives this away. Will just subrame connectors be enough or should i look into somethingh else? what else could i stiffen it up with thats not easily seen by glancing at the car?
Check out the internets only Turbo Pinto forum
www.planetboost.com/pinto
