Date: 03/27/2017 10:07 pm
Date: 07/17/2018 09:22 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 08/16/2018 08:54 am
Clutch pedal needed
Date: 01/11/2024 06:31 am
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
  • Online today: 344
  • Guests: 278
  • Total: 278
STROKER KIT
Started by pintoperformance, February 14, 2004, 06:30:19 PM
Late model 2.3L fords are also built as a 2.5L. I beleave the Racer Walsh web site has information on them. I understand the only problem is getting a front sump (Pinto) oil pan to seal at the rear main cap.
pyburn12
Try Race Engineering......They have the best bang for the buck....I bought one of their Pro 2.5 kits with ultralight componets....few pounds off the crank, light childs and albert rods, light pistons and pins..... comes as a whole assembly balanced for under 2K....great pulleys and belt systems too.
www.raceeng.com
2 LITER HONDA EATER
straw boss
The only ones I've seen are in the Esslinger catalog.  My old '97 catalog shows cranks that will get you up to 2850cc's with a stock block.
They aint cheap, however.  The '97 price list shows the kit (crank, pistons, pins and rings) at $1400.
On edit...
Esslinger's website appears to be down at the moment, but I just found a recent (12/03) flyer from them.  It shows a 3.875" stroker crank (2850cc) goes for $1475.  Apparently this is the price for the crankshaft alone.
pintoperformance
ANYONE KNOW IF THERE IS A STROKER KIT FOR THE PINTO 2.3???
MIKE
