Date: 04/24/2018 11:45 am
Pinto Watch
Date: 06/22/2019 07:12 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
nos core support
Date: 01/03/2020 09:39 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
1972 Pinto for sale
Date: 05/19/2021 12:41 am
v8 springs
Date: 05/07/2017 04:46 pm
Date: 02/27/2017 10:10 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
  • Online today: 548
  • Guests: 458
  • Total: 458
v8 engine swap
Started by 71scj429, November 14, 2006, 07:02:20 PM
fast34
Look in the parts for sale section on this site, there was someone with a M2 pan for sale cheap.
71scj429
thanks Robert     Shawn
71hotrodpinto
heres the page from The milodon site. Dont forget you also need the pickup to go with it.
You might want to check ebay if you have the time to wait. These pans are pricey new. Dont go with the knock offs that are on ebay. They look just like the Milodons but MAY not have the same construction and may not fit. Dont know.
Good luck
Robert
http://www.milodon.com/oilpans/pg06.htm
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
71scj429
thank you for that information ,could you give me a part number for the mildon pan?,i think trying to find a mustangII pan might be hard,i already got the hooker engine mounts and hooker headers from e-bay.have to keep looking maybe for oil pan on e-bay too. thanks for the help!
71hotrodpinto
 Hello,the closest fit for oil pans are the mildon 9 quart and the stock Mustang ll V8 pan and pickup. Most normal v8 pans wont clear the rack. The mustang 2 barely clears it. Youll also have to use a dipstick in the front so youll need a cover that will accept a dipstick as well.
Also theres exhaust. The eaisiest are the old mustang style manifolds. They go straight back and dont turn down.Then use a down pipe "home free". Headers are a major pain and you can either go custom like i did and make some fit down by the tunnel or you can use the Hooker header swap headers that go around the fender wells. Engine mounts are easy if you have the hard to find Mustang II engine mounts and frame mounts(they arent avalible aftermarket and ford stopped making them years ago. -Ebay ).
Just do a search here in the project section here @ Fordpinto.com and youll see a few clean installs. Should give you alot of hope and ideas.
If you want any specific questions answered ,let me know. Ill do my best or try to find out.
Good luck
Edelbrock Airgap
Mil
mustang pan won't fit, your need a front sump pan from a crown vic from the '80's (302) and even then it might need to be modified a bit.
71scj429
I'm installing a v8 86 roller h.o.302, in my 73 pinto, can a oil pan off a foxbody mustang work?,do i resort to modifying,or what  oil pan will work the best  ,also would a front sump pan work?any suggesting??? :lost: man!! it is a tight fit! thanks, shawn
