1975 Ford Pinto
Date: 01/13/2020 11:02 am
Date: 10/04/2019 08:43 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 04/13/2017 04:56 am
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
Date: 10/24/2018 07:35 am
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
  • Online today: 295
  • Guests: 174
  • Total: 174
cam/ manifold
Started by dandyferg, February 12, 2004, 10:17:41 PM
straw boss
It would be pretty hard to tell without pulling the cam, unless you have a roller in there.  No Pinto came with a roller cam.
The identification marks are located at the very back of the cam, on the surface that faces the firewall.
There should be some letters or numbers that are either scribed or stamped into the metal, and are usually not clearly visible.
For example, a Competition Cams camshaft would have something like "CC264H", or a Motorsport cam may have "M-2650-A237".
I don't have a stock cam handy to tell you what kind of ID marks it would have.
dandyferg
Thanks for you help,  I was told when I purchased this engine it had some mods is there any way to visually tell if I already have a aftermarket cam?
straw boss
I'll assume your 2.3 is in a Pinto.
You do not have to pull the head to change the camshaft.  You will have to disconnect the motor mounts and drop the radiator. Depending on your exhaust system, you may have to disconnect it also.  You should then be able to jack the engine high enough for the cam to clear the radiator support.
Oh, PS...
Be sure to cover the oil drain hole at the back of the head when you remove the cam retainer screws!
dandyferg
I have a 2.3 And I wish to change the cam,  The book say's to remove the head first is that only because of clearance reasons while in the car?  Also I wanted to change the carb and manifold I currently have a 340cfm autolite 2100,  do you have any suggestions?   thanks
