72 Pinto
Date: 03/07/2019 12:07 pm
Date: 06/07/2021 08:14 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 05/22/2018 01:54 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
Date: 07/21/2017 11:49 am
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
  • Online today: 481
  • Guests: 477
  • Total: 477
gearing
Started by mini stock racer, November 06, 2006, 09:07:16 PM
fast34
I would try to run a 6.40 final or close.  That will put you in the ballpark, 3.40 with 1.97 trans, or 3.00 with 2.14 trans.  That's for the Pinto M2 stuff though.
mini stock racer
1/3 clay nd running a 13 inch tire 185/70/13 now back when i had my pinto i ran the same tire but i had a 215 tranny with 340 rear end gear
fast34
Track size, tire size, and lap times will dictate which "final drive" ratio you need.  Basically, no matter the vehicle it works the same.  Give the information stated above, for a more accurate answer.
mini stock racer
well i no it's not a pinto but it's a ford ranger what gear's would you run in it to race on the dirt i no a 373 is to much would it be the same as the pinto run's i use to run a pinto with 340 in it
