Date: 08/01/2023 06:53 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Date: 09/22/2020 11:33 pm
Date: 03/16/2017 10:00 pm
Date: 05/28/2017 03:20 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
  • Online today: 614
  • Guests: 544
  • Total: 544
imitation factory rear speaker installation
Started by dholvrsn, October 06, 2006, 07:47:27 PM
Thanks for the good words!
BTW, is there a shallow sub-woofer, less than 3.5" deep, that I could install in the liftgate?
Here's the speaker on the other side and my indash. The indash is in progress. That was a long afternoon project.
You could probably do this on a hatchback. Those little lids on the sides call out for at least 3.5'' speakers. If not, cut those holes out for much bigger speakers!
Now on to the front speakers!
Here's the speaker and grill installed and a view of the back side.
Here's the metal panel cut out and then the plastic panel installed over it.
Here's the plastic panel cut out and test fitted for the speaker grill.
Here's the back side. The filler is held in with screws, fender washers, and Liquid Nails.
Plus the speakers that I am putting together.
Here's the side panel removed and then a 1/4" plywood filler added.
As far as I know, Pintos didn't come from the factory with rear speakers. But I used some Ford speaker grills to imitate a factory look.
Here are the before pictures.
