Date: 04/12/2017 06:57 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 07/21/2017 11:49 am
Date: 02/28/2024 02:07 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
Date: 03/14/2020 01:52 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
  • Online today: 489
  • Guests: 255
  • Total: 255
Question about 2.3
Started by demoiowa89r, September 09, 2006, 02:46:03 PM
demoiowa89r
When these engines get hot they seem to alot of power. But that is stock. What can be done to them so they don't lose that much?
Proud owner of a 74 pinto sedan. NON-DERBY
a 78 hatch. derby car.
a 73 wagon. derby car.
dale the pinto man
Thanks srt and 77turbopinto, The engine is a 2.0. I have 140.000 miles on the engine. The engine was rebut at 100,000 miles, can I buy a cylinder head with all of those mods?  I think my car is a bit underpowered, I don't want to race, just keep up a little better. Not that it mater's, I have a manual 4 speed. I know I'm like the rest of the Pinto owners, man its fun to drive em.
Thanks,
Dale
Head work: decking, porting, polishing, bigger valves, better valvesprings, solid lifters...
If you deck it, then go with an adjustable cam gear.
An undersized crank pulley is another thing to do, and there are lots more that can be done to, but it all depends on what you need/want from the engine and how much time/money you want to spend.
is the motor in the '71 a 2.0 ?  If so the head can be helped a lot by using a die grinder and removing metal under the valve seats and by tapering this metal from the base of the seat area down into the pocket above the valve head.  Pay attention to the area around the valve stem also.  It can be 'massaged' also to improve flow.  They 2.0 responds real well to this type of work.  Matching ports too is a good idea
dale the pinto man
77turbopinto,
What do you mean head work? I enjoy your expertise.  I have a stock 71 wagon and I have been kicking around the idea of doing some work on my head because of unleaded fuel, while I'm at it, is there anything else I should be thinking about doing? I use an additive now. Thanks.
Dale
A turbo would not give you much low end power where you need it, and be MORE prone to damage and overheating, not to mention having senitive electronics if you use an EFI set up.
IMHO: Get a good cam and exhaust, and maybe drill out the jets a few sizes. Keep in mind that the thing that really seems to bring these engines to life is head work.
I would think that a low geared rear would help just as much for a demo, open or welded.
2point3turbo
If turbo is allowed, go that direction if not then I am sure you can find some info in the faq on power buildups.
demoiowa89r
I was wondering what should i do to build a hi-torque,hi-HP 2.3.  I have a 2.3 out of a 78 pinto. I'm building a derby engine and i need more power.
