Date: 06/22/2017 07:19 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 02/16/2019 10:46 am
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
Date: 03/25/2019 09:02 pm
Date: 10/10/2019 09:42 pm
Date: 06/24/2020 06:12 am
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
  • Online today: 452
  • Guests: 420
  • Total: 420
Coolant circuit diagram pinto 1980 with 2.3
Started by Erakiel81, September 02, 2006, 10:34:24 PM
Erakiel81
I'm searching the diagram of the coolant circuit for a 2.3l pinto 1980. I'm not sure if mine is correctly mounted. I have compared to other 2.3 but they missing some hose compared to mine. I've got one hose going out from the water pump to the heater core. One other going from the heater core to the small exit on the thermostat cover, This line have a T adaptor going to the air intake.
I suspect an error in the mounting because my motor generate an huge amount of heat...
Any help is welcome
