77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 10/01/2020 02:00 pm
Date: 09/10/2018 10:41 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
1979 pinto
Date: 04/19/2018 02:02 am
free transmissions
Date: 11/28/2019 10:21 am
  • Online today: 481
  • Guests: 220
  • Total: 220
351 DOOE heads on a 302
Started by Underdog76, January 19, 2004, 05:25:28 PM
The Lemonator
Im running C5AE 289 heads on mine.
1.94 intake 1.60 exhaust w/ 280lb springs.
Ports are opened up all the way.
Screw in studs.
Roller rockers.
I like the 54cc chambers. Around 11:1 compression with flat tops.
They are good to around 7200rpm.( I usually only turn it to 6500)
Ran 11.85 on pump gas in my buddies 2600lb sedan. (His broke, so I loaned him my new motor)
Should run 11.40s in mine on alcohol.
73 Sedan, 302 on Alcohol, C-4, 9-inch, 11.59@114(so far)
Underdog76
Well Thanks for thew reply. My dad and I are running this combo on his 71 pinto coupe. So far it's pushin around 460 hp without many power additions, only Roller Rockers, a decient crank, an oridginal Torker intake with the diagonal carb, headers, and a .30 bore job. Our carb is a 760 cfm Holly with .71 jets. I think the exhaust valves are 2.10 or 2.11. I've heard that the heads flow somewhere between Gt-40 heads and Gt-40P heads.
Fast as lightning, strong as thunder
SVOwagon
I did this to my old 88 stang. You'll get a little more compression, bigger valves( I know that the intake is 1.84, but forgot what the exhaust is) and the intake port is a little bigger also. The exhaust port is the same size. When I put my 351 heads on my 80 302 block, I had to use 1970 351 intake gaskets. The head bolt holes are bigger also. I just put washers on my bolts. These heads helpped me get a little over 300hp from my small block. With other parts as well. I did a lot of street racing back in the day. I even keeped track. I was 23 and 0 ::) Never lost a race!
 SVOwagon
80 2.3 EFI Turbo Pinto Squire Wagon
91 Mustang LX 5.0 (93 Cobra clone project)
82 Mustang GT (built 460)
89 Mustang LX coupe (built 302)
83 Ranger
http://www.cardomain.com/ride/2167062
Underdog76
Does any one know anything about the pottential of DOOE heads  when put on a 302?
