V8 rear end
Date: 04/12/2018 10:57 am
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Built 2.0
Date: 10/07/2018 05:27 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Date: 10/31/2018 12:00 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 06/05/2018 09:13 pm
  • Online today: 179
  • Guests: 202
  • Total: 202
power steering
Started by krazi, August 22, 2006, 12:21:07 AM
krazi
I have been running regular steering fluid. what grade/type of trans fluid do you recommend?
krazi
yeah, I'm Krazi!
I have looped the rack lines on my racecars and pulled the pumps off, and I have seen 2 kit cars with power racks and fuel filters where the lines attach.
It will most likely have a different ratio than a 'regular' manual rack, but I think it will work for you.
I need to ask: what fluid do you have in the pump? Regular p/s fluid will kill these Pinto pumps, not to mention make them very noisy; They do die with the correct ATF too.
krazi
the steering pump on my wagon pooped out on me a few days ago, and I needed to get to work, so I took the belt off. I like the way it sounds without that whiney pump, so I was wondering.... would I be able to use my new tie rod ends in a manual rack? if not, one trick I heard is to fill the rack with fresh fluid, and move the lines so the in goes straight to the out. kinda like a U. any advise would be appreciated
krazi
yeah, I'm Krazi!
