Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 06/12/2018 08:18 pm
Date: 08/05/2018 01:58 pm
77 pinto
Date: 08/22/2017 06:31 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
Date: 08/13/2018 02:46 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
Date: 02/18/2017 05:55 pm
  • Online today: 586
  • Guests: 466
  • Total: 466
Warning Lights
Started by gpinto2, August 16, 2006, 04:46:14 PM
gpinto2
Thanx,I'll check into that!!!!
1972 Pinto 410,C-4
oldcarpierre
Back in 1981-1982, I owned a 1980 Chrysler Cordoba.   This car came had an amp-meter with a charge/discharge needle.   It also had a tiny red light that came on when the needle was too deep into the discharge range.   I thought it was a great idea and I figured it would catch on, but aside from the yellow light that tells you your fuel gauge is nearing the empty range, it never did.
Perhaps you can find inspiration from the wiring diagram of the 1980 Cordoba?
gpinto2
The water temp should be easy enough on the intake,the volt meter light should go down to the alt. with a sender in-line somewhere and then I should need a T off the oil pressure to fit both the sender and the mechanical gauge?
That sounds right,let me know if I'm on the right track on this... Thanks
1972 Pinto 410,C-4
wagonmaster
Warning lights use a different sender than an electrical, or in the case of a mechanical gauge, which will have no sender. A "T" could be used to attach the proper sender for a light along with the connection for a mechanical gauge or the sender for an electrical gauge. For temp, it may be easier to find two locations for the light sender and the gauge hookup. Senders for lights are triggered by reaching a preset threshold, whether it's a high temp or low oil pressure, causing a gound and the "idiot" light to glow.
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
gpinto2
I am thinking of adding warning lights off to the side of my gauges,so if I'm not paying attention to the gauges I will see the light.
Has anyone ever done this? I would like to figure out how to do this,if anyone has done it or at least knows how please let me know what to do!!! Thanks
1972 Pinto 410,C-4
