77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Date: 08/22/2018 09:23 am
Date: 04/04/2020 09:38 am
Date: 12/20/2016 10:47 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 02/18/2017 04:47 pm
  • Online today: 515
  • Guests: 399
  • Total: 399
Cant get 74 Wagon to run.
Started by pintoguy76, August 15, 2006, 12:09:30 AM
See new topic. The engine blows zero compression on cylinder #1, and 115 PSI on 2, 3 and 4. I would think the engine would start and run, just run like crap. It will once in a while start, but wont stay running more than a second or two and thats with my foot to the floor.
I think there may be an internal engine problem. The engine does not sound the same as it does on my other pinto and they have the same engine. It sounds as tho it does not have any compression. Ive felt  air blow out of the #1 cylinder but when i stick my finger on the hole and crank it i never feel it blow against my hand and it will not pump up on a compression check. However. The compression tester i bought was very cheap ($5) at harbor freight and it could just be a chinese made (c)HEAP. I'm gonna run a compression test with it on my other pinto and it runs so i know it has compression . That will tell me if the guage is bad or if its the engine.  I know the belt is on correctly and it wouldnt pump up even when i aligned the timing marks on the cam and the pointer for the cam, and that should be set for compression stroke on cyl 1 (both valves closed) . So its sounding to me like i have a compression problem, likly in the head. Does anyone else agree? The 2.3 engine is not an interferece engine, so cranking it with a broken or missing timing belt will not bend valves or damage pistons. The only thing i can think of that would caus me problems is if maybe theres some broken valve springs or something.
goodolboydws
cookieboy said it.
Points type ignition systems are a world unto themselves and if you have no basic understanding as to how to install  and set the points and why certain things have to be done or avoided, you will have no end of ignition related problems that seem to be unsolvable.
In a nutshell, modern electronic ignitions are mostly drop it in, bolt it down, if it fits, it works, and they generally either work fine or don't work at all, while points ignitions require very precise setting to work even ADEQUATELY, much less well, and will gradually change performance as the points themselves physically deteriorate over time. That's why they are almost extinct. To perform well, they require careful and (relative to electronic ign.) frequent attention, and few people have the time, tools, knowledge or interest in maintaining them.
Do some serious reading to find out how points type ignition systems work in general, then read up on how YOURS is supposed to be set up. It's not really DIFFICULT to do, but it does require basic knowledge.
joecool85
You could work with the points/condensor as that is probably your issue, OR you could just replace it with an electronic ignition from a newer 2.3, thats what I recommend.  There are a few threads on it if you search.
Life is what you make it.
http://www.thatraymond.com
It is possible that the points are not set properly or the condensor is bad.  I would replace the condensor regardless as they can cause wierd problems when they go bad.  They are cheap, like $3-$5.  unit I always kept a spare condensor in my Mustang.  The point gap or dwell does affect the ignition timing.  You need to make sure the dwell (point gap) is set properly before you adjust the timing with a timing light.  To adjust the points you will need a feeler gauge and a flat screw driver and a remote starter. Take the cap and rotor off the car and bump the engine till the rub block of the points is on one of the corners of the shaft.  Resting the rub block on the corner should open up the points.  With them open, inspect the points for pitting and uneven wear.  If they look too bad, replace them and the condensor before continuing.  If they look ok, take the feeler gauge and check the gap according to the spec.  If there too tight or loose, then using the screw driver, adjust them accordingly.  Once you have the screw tightened, I like to crank the engine over and check them again before reinstalling the cap and rotor.  If they check out accordingly, I install the cap and rotor and start the car and check the dwell with the engine running using a dwell meter.  My 67 Mustang always had a dwell range of 37-42.  It always ran the best being set at 39.  I recommend to eventually swaping to electronic ignition.  I swapped to a pertronix unit in my Mustang 10 years ago and have not had a problem.  At the time, points were about 10 bucks a pop and I would replace them about once a year to keep the car running top notch.  Hopefully your points are causing you the problems.  Remember to set the dwell before you set the timing.  Good luck!
learn points... made a world of difference w/my car (73 Runabout)
I took delivery of my 74 wagon today (2.3L) and spent a few hours trying to make it run. It started for a second and that was it. It tries alot to start but just wont do it. It acts as tho the timing is off. I know the timing belt was off and the previous owner retimed it and said it was in time. I looked and i think the cam was 180 off so i retimed the whole thing (ive done this before, so surly i did it right this time? i mean i made it work without any problems before on another 2.3 pinto) and it seems better but still wont start. It really acts as tho its off time. backfiring thru carb, cranking and stoping....cranking and stopping... depending on how i have the whole thing timed (i keep changing things around thinking maybe ive done something wrong, tho i dont think so. id swear its right, as it is now!) It has a new carburetor on it, and it appears to be getting fuel (as it is backfiring from the carb and the float bowl is full) and ive checked spark, the test light i bought (inserts between plug and wire and has a bulb in it) seems real dim, but then its a points type ignition, they dont have the hottest spark to begin with) but it does have fire. This is all pretty apparent since it does try to start just doesnt succeed. Everything acts as tho its off time but id swear it is not! I lined up the timing pointers below the cam pulley and ON the cam pulley, set #1 piston at TC on compression stroke, adjusted the aux. shaft pulley to where the ignition rotor is set to fire the #1 plug, and then slipped the belt on right there and tightened it down. Never seems to improve no matter how many times i do and re-do that. Now then. It is a points type, being a 74 model. The only year of the 2.3 to ever get points. I know nothing about points. Is it possible the points arent set right or something? It looks as tho theres some new parts there in the distributor, the points parts...(dont know what they are called). The only thing i can think to do now is just keep retiming in, in case maybe im not getting it at TDC on the compression stroke... tho i feel a good burst of air shoot out the spark plug hole. Ive checked and rechecked and rechecked the firing order (1342), making sure i dont have it set to fire backwards (made that mistake before!). I'm just at a loss. Anyone got any ideas?
