Date: 05/22/2018 02:27 pm
Date: 03/06/2017 01:19 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 10/10/2019 10:02 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Date: 10/05/2017 02:26 pm
Date: 02/28/2018 09:33 am
Date: 09/10/2018 10:41 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
  • Online today: 295
  • Guests: 190
  • Total: 190
Starter issues
Started by FCANON, August 07, 2006, 04:32:21 PM
Gaslight
As well as the other items already mentioned and should be checked first is the resistence in the battery cables and the starter bendix.  If the Bendix is not moving freely that would cause this.  Is it a rebuilt starter?  You might want to try another starter to eliminate that.
Jake
what size cable are you using?  should be as large as you can get
Have you checked the block ground?  I had a starter problem with our Explorer recently, it was the block ground on the back of the block.
Still fighting this thing....
the starter to me is drawing too many amps. I crank it with my charger set on boost 225 Amps and it will turn over a little better, or should I say enough to fire off....
The battery is a Optima 800 CCA.
I've replaces the Cable from the starter relay to the starter.
A new solenoid.
New starter.
The cables seem to really hot after cranking....
It just seems to me it should start rather normal...I have built hotter motors and they all started rather easy. the only difference is the battery in the trunk....at this point I'm venting....
Frank
Farmboy
I learned something new last nite, going to put the starter in my fresh 2.0. I have 3 starter's , 1 that is a year old from the 2.3 and 2 that are from the 2.0 that are very old. Oh my God, they sure look the same. Call NAPA and check it out the starter are the same, easy choice put the new one in and call it good ;D
74 Pinto Wagon
71 Runabout (parts car)
Well I replaced the starter .... looks like my biggest problem is the old cables from the trunkmount
Or the safty cut off switch.....
Frank
OK... I pulled my 72 out and i forgot the problems I faced before I parked it. I kept getting weak starters.
The scoop is I have a Mustang II 4 speed bellhousing and fly wheel.
With the motor,  Headers  and cross member its a big ordeal to replace the starter.... So is there a good referance on a starter with out buying a mini starter?
Frank
