Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 10/24/2018 07:35 am
Date: 08/22/2017 09:21 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Date: 10/28/2018 08:45 am
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Date: 02/28/2018 09:18 am
Date: 07/30/2018 04:32 pm
  • Online today: 600
Changing stock leaf springs with racing track springs
Started by snakeriver_man, August 05, 2006, 04:09:16 PM
robw
why not take the main out of the old ones and put it the new ones
wagonmaster
Hey 71hotrodpinto,
Thanks for that input! I learned something myself in the process. Not having messed with any Pintos earlier than '77, I didn't realize that the early rear springs were shorter and could be part of the issue. Thank you!
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
71hotrodpinto
Hey there, been there done that .
All the aftermarket springs are of the 74-80 variety. They are longer than the 71-73 leafs. To make them work temporarily you can turn the hangers around to extend the shackle mounting point, BUT the shackles will rub the valence and ruin it. I tried to shave my shackles down to clear, but they still ended up rubbing and putting creases into my valence. ALSO I noticed that the wheel wasn't centered in the wheel-well anymore it was shifted back about 3/8". So I went back to my 71 springs.
If you want some new springs for your 71 then you need to take them to a spring shop for re-arching or look on-line for shops that make springs up from scratch for proper fitting springs.
Good luck man.
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
wagonmaster
Actually what you need is shorter main leafs. When the leafs are flattened, if they start out at stock length, it's as though you hit a hard bump. In a normal situation with stock springs, this would cause the shackle to deflect to the rear. With the leaves already flattened on the springs you have, it forces the shackles back as though you had hit a bump and caused the leafs to deflect. You may want to check with the spring supplier and see if he has a slightly shorter mainleaf spring or check to determine if the leafs you received are the correct ones.
Brien - wagonmaster
'85 LTD LX
snakeriver_man
I swapped the stock leafs with a stiffer, flatter leaf spring set for track racing which lowers the car and allows the 15" rims with a 205\50 low profile sidewall to set within the wheel wells very nicely however this has caused the shackles to rotate to a horizontal position when I lower the car onto the tires. I am thinking I need shorter shackles to minimize the rotation?
snakeriver_man@hotmail.com
Karl Schmidt
