Date: 08/16/2018 08:54 am
79 pinto steering column
Date: 08/18/2018 02:00 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 05/22/2018 01:54 pm
Date: 10/10/2019 09:42 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 10/26/2020 03:24 pm
  • Online today: 802
  • Guests: 110
  • Total: 110
73 Pinto 1600 stick - What Mileage? Durability?
Started by Starliner, August 05, 2006, 12:28:41 AM
Starliner
I just picked it up the car and drove it over 800 miles.  It got 30 - 35 miles per gallon at 70-75 miles per hour!   The de-acceleration valve was bad.  It ran better under load.  So it ran better going up the hills than down the hills  :lol:    So it should even do better later after I start to work on it.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
those 1600's were used in a bazillion english cars and are the starting point for the twincam motor that Lotus used in their cars a few decades ack.  i had a lotus elan sprint at one time, a 1974 big valve model and the twin cam motor in it is based on the 1600 ford bottom end
fast34
Had a 71 that would average around 28-30 on the hi-way.  This was all stock.  As for a dist. upgrade--Go try and find a factory unit out of a mid to later 70's Fiesta, they used the same basic engine and it had a HEI in it already.  I did this and was able to use the standard Pinto control box.  Worked very well, and only cost me about $35 to do and about an hours worth of time.
that 1600 is a tried and true workhorse.  i think you should put a header and an exhaust system of at least 2" from the header to the rear.  going larger on the exhaust may get a bit more top end but you may lose bottom end and mid range power and if you go too big you WILL get a LOT of noise inside the car.  be careful on rejetting.  it's so easy to go too big.
Starliner
I recently purchased a 1973 Pinto 1600 4 speed on Ebay.  It has 22,000 original miles.  It has some minor rust and I probably over paid at $3000.00   However my purpose is to replace my present beater car that gets 17 mpg and I travel 110 miles a day.   So I should be able to drive this for 3 years trouble free and junk it.  No car payments and easy to fix.  (I will rust proof it to extend it's death and improve the gas tank)  So from that point of view it is a good investment.  I will pick it up this fall.
I plan to run Mobil 1 oil, do some minor tweaks like recurving the distributor, electric fan, and radiator overflow.  Otherwise keep it stock.   If I get hooked, I may buy another Pinto for modifications.
I have had many 2.0 Ford products (Capris & Mustang II) and have worked on 1.6s.  But I never owned a 1.6 for myself.
Questions:
1)  What mileage can I expect out of a 1.6 with a stick shift?
2)  Any issues with the 1.6 for long life?
3)  Any kits to replace the points with electronic ignition?
