Date: 05/13/2021 05:29 pm
Date: 04/10/2017 07:30 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 03/06/2017 01:24 am
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Date: 03/06/2019 06:40 pm
Date: 05/19/2018 04:56 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
  • Online today: 489
  • Guests: 359
  • Total: 359
does anybody know what crank fire ignition is?
Started by madmax96101, August 04, 2006, 12:33:39 AM
Gaslight
Ooops.  I probably should have mentioned that the technical name is DIS or Direct Ignition System.  This should get you started.
http://en.wikipedia.org/wiki/Ignition_system
Jake
madmax96101
thanks for the help gas light. i tried google before i posted here. i couldn't find anything about it. thank you.
CHEAPRACER
Those auto parts stores crack me up, ...I think someone built in certain questions to their parts programs just to make the parts guy look stupid. You should have told them neither, it has EFI.
Gaslight
Basically no distributor.  All the timing is taken off the crank.  There are different ways it is done from external sensors to internal units.  You should be able to find lots of examples on the internet with a google search.  There are even some aftermarket systems you can use on your 2.3.
Jake
madmax96101
my 2.3 is carburetor. 1974. i just have never heard of crank fire ignition. if you could describe what crank fire ignition is i would be very happy. thank you for the reply.
Gaslight
Which 2.3 is this?  There are a couple of different types of crank fire ignition systems but all the factory units are found on EFI controlled cars.  For instance the Corvette has been using it for some time now.  Never seen a 2.3 with one except for aftermarket.
Jake
madmax96101
I'm thinking about maybe getting a new carburetor and in the notes it says the 2.3 is going to need to have crank fire ignition to work. thank you for the help.
