Date: 04/27/2018 10:28 pm
Date: 08/26/2018 06:35 pm
Date: 03/29/2019 07:20 am
Date: 04/13/2017 04:56 am
Date: 02/10/2017 09:30 am
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 09/19/2019 04:43 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
FLOOR PANS
Date: 06/12/2020 07:24 pm
  • Online today: 533
  • Users: 1
  • Guests: 76
  • Total: 77
Installing Sport Mirrors.... Need the screw inserts?
Started by TIGGER, July 30, 2006, 03:19:14 AM
Thanks Bill, I the inserts came the other day.  I installed them tonight.
Will do, Thanks.  I need to order some other parts anyway.
It is not in the catalog, you need to call them. Ask for Kevin Gormley, tell him Bill Rainey told you to call. He is the tech guy there, and knows all the part #'s.
Thanks for the input guys.  I looked thru my Mustangs Unlimited catalog and did not find anything.  I will take a look again.
If you can't lay hands on a "riv nut" kit, you should be able to use some 3/16- 1/4 plate cut to match the mirror base. Then drilled & tapped for appropriately sized bolts. If there's enough force to pull this plate through the doorskin, then the mirror's toast anyways! LOL I used this method on my '74 MII.
Mustangs Unlimited in Manchester CT sells a kit with the riv-nuts needed. I used their kit to install the right side mirror on the new door on Connie's car. The kit is cheap, but you should get a hardened bolt and nut for the install, and I reccamend tack welding the nuts after installing them just to be sure (a small tack on the rear of the front one and on the front of the rear, there is room for a small weld).
I want to install sport mirrors on my 73 hatchback.  I installed the drivers side today.  It was fairly easy.  I have the matching passenger side (non remote) with the molding but I do not know where to get the inserts for the screws.  Does anyone have any idea's?
