Racing seats
Date: 10/24/2019 09:41 pm
Date: 09/17/2024 12:35 pm
Date: 06/24/2020 06:12 am
1979 pinto
Date: 04/19/2018 02:02 am
Date: 09/06/2020 01:57 am
v8 springs
Date: 05/07/2017 04:46 pm
Date: 06/07/2018 01:45 am
Date: 10/01/2020 02:00 pm
Oddsnends
Date: 12/20/2016 10:52 am
  • Online today: 531
  • Guests: 263
  • Total: 263
C3 and a 2.3L
Started by FCANON, July 26, 2006, 04:13:33 PM
272 it looks like....humm might need a 3:55
Frank
fast34
What rear gears does it have??? May have a high ratio in it.
Gaslight
Take a look at the distributor and make sure it is advancing correctly per rpm.  Also make sure you are getting the correct amount of vacuum at the distributor.  Make sure the rubber house to the distributor is not leaking.
Jake
OK I just thought I would through this out...my 76 wagon is a C3 with a 2.3L.... this thing starts with a little flick if the key, revs very crisply... but when you throw it in gear is has no Ba!!z...
Out of all the Pintos I have owned I never had a Auto combo that was so gut less. This thing shifts well , just takes too much motor to make it move. Any sujjestions before I go mess with it.
Frank
www.PintoWorks.com
