Date: 05/13/2021 05:29 pm
Date: 10/25/2019 04:05 pm
free transmissions
Date: 11/28/2019 10:21 am
Date: 07/17/2018 09:22 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
postal pinto
Date: 06/03/2020 09:31 am
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Date: 01/28/2021 03:49 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
  • Online today: 489
  • Guests: 370
  • Total: 370
Setting timing on car.....
Started by Nevada Pinto, July 25, 2006, 05:40:57 PM
Gaslight
Glad to hear it worked out.
Pinto on!
Jake
Nevada Pinto
Perfect.....I just got done doing the distributor installation.....I removed the #1 plug just to make sure it was at TDC...And also removed the cap to make sure it was in the location of the #1 cylinder...Thanks again for all the help...
Gaslight
I am guessing you did not note the position of the old distributor when you pulled it out.  You will need to rotate the motor around until the timing marks on the crank line up at TDC and the number 1 piston is on its compression stroke.  The install the distributor with the rotor pointing at the number 1 spark plug wire on the cap.  That should get you close enough (or even maybe) right on the money.  Set the timing from there.
Jake
Nevada Pinto
Another Question.....I have the new distributor that I'm going to install what do I set the motor at before I drop in the new distributor....TDC Or at zero..
Nevada Pinto
 Thats what I needed to know...Thanks denny...I was setting it at 16 degrees over TDC...Ran but not good....
johnsonracing
Okay Brad,
  Here's the deal.Run electronic if you can.I take some Jb weld or epoxy product and lock my vacuum advance.When I set my timing,I run the car at about 3,000 rpm.This is so you get full mechanical advance.Set the timing at about 28 degrees BEFORE TOP DEAD CENTER.This is actually retarded for normal driving,but in a demo car you do not want detonation to occur when it gets hot.
  How was Faribault demo?I suppose Jason was there?
     Denny
Tude
pm sent
when the dist is in the right spot (1/4) and the moter is very warmed up just about to hot
loosen the dist
while the moter is running turn it back and forth
this will let it run better when it is hot and start easier
it will start a little hard when it is cold but it wont stay cold for very long if you drive like i do
custom fit hammered and bent
Nevada Pinto
I was wondering what the correct timing is for a points distributor a 2.3....Im going 16 degrees over TDC...
