Date: 12/15/2018 02:21 am
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Rear Bumper
Date: 07/26/2021 01:08 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 07/17/2018 09:22 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 04/27/2018 10:28 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 10/31/2018 12:00 pm
  • Online today: 452
  • Guests: 244
  • Total: 244
Better brakes in front, mustang donor?
Started by joecool85, July 24, 2006, 09:11:15 AM
joecool85
I was using this site: http://www.mrt-wheels.com/boltpatternref.html
For reference and it said that 4 x 4.25 is the same as 4 x 108.  And that the mustangs used it as well.
Life is what you make it.
http://www.thatraymond.com
Quote from: joecool85 on July 24, 2006, 09:11:15 AM
Ok, pintos are 4 x 108 correct?  I have searched and noticed no posts about using mustang rear ends (from 79-93 they used 4 x 108) or mustang front hubs/brakes etc.  Any reason why you couldn't use mustang stuff?
All stock pintos are 4 on 4.25", I think that is the same as 108mm. Fox body Stangs that have 4 lug are the same.
There is info out there; it says that those parts do not directly bolt to a Pinto so modification (some of it is major) will be needed to do a swap with those parts.
There are brake up-grade kits out there for Pinto front ends, depending on the year of the car. I have Granada rotors on mine and big Maverick drums on the rear (all 5 lug).
joecool85
