sport steering wheeel
Date: 10/01/2020 10:58 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Date: 01/19/2020 09:06 am
1976 Pinto
Date: 10/24/2017 02:00 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 09/21/2018 11:35 am
Date: 07/30/2018 04:32 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
  • Online today: 216
  • Guests: 254
  • Total: 254
Pinto up keep
Started by pintoman, July 23, 2006, 05:25:04 PM
Gaslight
You can run the turbo without water at all.  But you will beed to run a turbo timer in place of it.  There are quite a few turbos which show a longer life without the water.  The Toyota CT-26 and CT-20 leap to mind but there needs to be a turbo timer added.  Although on the garrett turbo the water passage through the turbo is a much better design and the water cooling works better on this turbo than a turbo timer.  Although using both together is the best way to go.
Jake
CHEAPRACER
Think positive, now you have a t-5, roller cammed 2.3 with a new headgasket & running the turbo without water might not hurt a thing in a lightweight Pinto if you use a high quality oil.
pintoman
Sorry Bill your luck did not rub off.Thats the way it is for me all the timeHere is a pic ture of the engine bay.
Sorry if some of my "luck" rubbed off on you when we met.
pintoman
I just spent the last 4 weekends getting the Rallye back on the road.4 weeks ago the clutch went out of the car.A friend had a t-5 setting in the garrage.After talking him out of it,i drooped the t-9 out of the car and installed the t-5.Every thing went smooth until i got to the drive shaft.It was two long for the t-5.The following weekend my buddy gave me a shaft from a xr4ti,it was wayyy two long.Got mad and went home.Then last weekend i got a shaft that works perfect.So Friday morning was going to drive the car to work,started it up and nothing but white smoke out of the tail pipe.Blew a head gasket.Saturday i removed the head,put it on my work bench.The cam shaft was wiped.So i put in the rollercam that i had.So wile i had the head off i decided to paint some of the engine parts.Now the engine compartment looks good ,but i now have a major water leak on the turbo.Now the car is fixed and in just 4 weekends.I will post pictures later in the week.
