95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 11/02/2019 10:25 am
Date: 05/19/2018 04:56 pm
Date: 08/03/2018 09:19 am
Date: 07/04/2022 07:55 pm
Date: 10/05/2017 02:26 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
Date: 10/24/2018 07:41 am
Electrical
Date: 03/29/2017 11:37 am
  • Online today: 535
  • Guests: 493
  • Total: 493
87 2.3 Block
Started by The Lemonator, January 04, 2004, 03:50:44 PM
straw boss
I thought the smaller crank journals showed up around '89 or '90.  Could be wrong however.
One thing that is different for sure is the '87 block has a one piece rear main seal.
I think that due to the different seal, the crank would have to be different also.
 Yes , the crank journals are smaller than the 2.3.
The Lemonator
Got the block. Everything looks OK so far, but I have not pulled the head off. One thing that I noticed, the mechanical fuel pump mount in the block is not cut out. No prob, I can use an electric. Might even use the serpentine belt.
It was a clutch car and mine is an auto, I hope the crank balance is the same so I can use the old flex plate.
I'll let you know.
My racecar is so much easier to deal with.  :)
73 Sedan, 302 on Alcohol, C-4, 9-inch, 11.59@114(so far)
don't they have a smaller jounal on the crank? (the 2.5)
 OR, you can get a Ranger 2.5 short block ....... ;D
yes the 87 block will work. You can get rebuild kits from summit that come with pretty much evrything.
The Lemonator
Anyone know if a 87 2.3 block is the same as a 78 2.3 block.
The 78 spun a rod bearing and a friend has a good running 87 that i can get cheap. I know that the head is different on a fuel injected engine, but I don't know if the block changed.
My plan is to bolt the 78 head on the 87 block and be back on the road in a flash.
If they are not the same, will the crank from the 87 work in the 78. Even if I rebuild the 78, I will probably still need a crank.
Also, what is a good source for 2.3 rebuild kits?
