1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Date: 09/09/2018 03:22 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 04/13/2017 04:56 am
  • Online today: 447
  • Guests: 377
  • Total: 377
1973 Pinto Wagon Engine and Tranny Swap
Started by ltursick, July 19, 2006, 12:36:10 PM
Farmboy
  I'm doing the 2.3 to a 2.0 this weekend if it aint all that hot in the garage, hopefully mine will go as easy as yours ;D
74 Pinto Wagon
71 Runabout (parts car)
ltursick
Both cars lack power brakes, so I guess I should be fine. Thank you so much for the help!
Luke
grgic
Quote72/73 Power brakes
Sorry wasn't thinking of years Just know they are different
grgic
Luke;
I just put a 2.0 and manual trans from a 73 wagon into my 72 2.0 auto.
It all swaps out perfect the clutch and brake pedals and cable go onto the automatic car, my fender well even had the screw hole for the clutch cable hold down. the manual shifter comes out in the same spot as the auto shifter. the only problem you might have is if one has power brakes and the other has manual brakes. the pin for the master cylinder rod is offset and your brake pedal will be too high or low depending. you will need to use the drive shaft from the trans you are using.
I did the whole swap in in my driveway in about 3 hours
good luck
Joe
ltursick
I have a 1973 Ford Pinto Wagon with a worn out 2.0 with bad compression with an automatic transmission. I just bought another 1973 Ford Pinto Wagon with a strong 2.0 and a manual transmission and I would like to swap this drivetrain into my first wagon. What all do I need to know? Is there any fabrication? Can I do this in my garage? Thanks for your help.
Luke
