Need Interior Panels
Date: 07/09/2018 04:59 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Date: 01/23/2017 07:41 am
Date: 02/04/2018 08:26 am
Date: 12/31/2017 11:14 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
  • Online today: 210
  • Guests: 208
  • Total: 208
sunpro minitach
Started by dholvrsn, July 19, 2006, 09:37:25 AM
i turn 3k 2 almost 70. 3.00 rear gear, 1:1 trans final drive, 175 8 r 13 tires.
krazi
Quote from: dholvrsn on July 22, 2006, 06:01:48 PM
PS: I did quantify the subjective "a little buzzy" into being 2600 RPM at 60 MPH. Later, when I couldn't sleep, I did the math to figure out that meant 3.08 rear gears.
I believe my earlier Pinto had 2.73 gears because it turned 2400 RPM at 60 MPH.
wow. I turn close to 3 grand at around 60. not sure if it's the speedo being off or not. maybe a low gear in the rear. it does have an 8 inch.
krazi
yeah, I'm Krazi!
I pretty much figured it out just about a few hours after I posted here. Kind of lost a half hour fighting a bad ground and getting the selecter set just right. That thing's fussy but has a week detent.
I have the same tach  on my pinto. i ran both the the white and the red wires to a spot that is hot when the key is on.The green is the signal wire, it goes to the negative side of the coil and the black wire goes to a ground. Be sure and set the switch on the back to the 4 cylinder setting, unless your pinto has a V6 then it needs to be set on the 6 cylinder setting.
BlueGoldPinto
This is just a guess but, from my experiance, "Green always means ground" Good luck!
BGP ;D :D ;) :) :) :) :) :) :) :) :) :) :)
DragonWagon
Does it only have these two wires?  ???
On current Sunpro mini tach II's, the green wire goes to the negative side of the coil, and the white hooks up to your gauge light circuit. They also have a red hot lead and a black ground.
See a list of their manuals here - http://www.sunpro.com/user_manuals.php
If it only has the two wires, I would guess one is ground, one goes to the negative side of your coil. Which is which, I don't know.
1976 mpg Wagon. The start of it all.
1977 Cruising Wagon, to be turboed.
1979 glass hatchback. No motor atm.
1980 wagon parts car.
Picked up an used SunPro MiniTach for Wee Beastie, my "Pinteaux", with no documentation. So where does the green wire go and where does the white wire go?
