1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Hatch needed
Date: 09/10/2017 09:16 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 06/12/2018 08:18 pm
Date: 10/25/2019 03:30 pm
Date: 01/06/2017 11:42 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 03/17/2019 10:15 pm
  • Online today: 210
  • Guests: 180
  • Total: 180
2.0 SOHC 1970's Enigine rebuild help
Started by The Lola Registry, July 15, 2006, 09:19:36 PM
Yes the squirter is on the left if looking from the front of the motor.  If you are working with a stock parts, the piston has an arrow on its top giving the direction also (the arrow points forward and is located on the piston's top in the forward most location).
FYI: In the manuals, the convention is to look at the engine from the back when assigning right and left.  So using this orientation the squirter would be on the right and the numbers would be on the left.
Jerry J.
The Lola Registry
Obscuure question.  Trying to confirm the direction of the pistons and rods on a 2.0 SOHC Pinto motor.  The rods have a oil squirter on one side of the rod half way up.  Facing the front of the motor are the squirters facing left?  Thanks Allan
