Date: 08/17/2022 06:27 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
Date: 08/26/2018 06:23 pm
Date: 07/11/2023 11:39 pm
Interior Parts
Date: 08/07/2017 03:59 pm
Date: 01/10/2022 03:41 pm
Date: 04/25/2017 12:17 pm
pro stock front end
Date: 06/28/2019 07:43 pm
Date: 01/19/2021 03:56 pm
  • Online today: 583
  • Guests: 380
  • Total: 380
Timing on 1977 2.3
Started by Cookieboy, July 15, 2006, 06:33:12 PM
 :wow: I found some info that indicates that the advance should be around 20 so I went ahead and checked the timing.
I marked the pointer and the 20 and...... I don't see the mark when I check the timing.
so I tried the light on all areas I could see from above and still no mark.
then I crawled under the car and.... there is the mark.... appox 180 degrees off  >:(
now get this... the car runs and drives... has hesitation if I punch it but if I drive nice it goes OK. Starts right up and idles ok w/very slight miss.
I called a friend and he thinks.... that timing belt is off by a tooth or two???
What do you all think??? help please??? advice???
got the new distributor in now I want to check the timing...
book says "refer to lable inside engine compartment" for the ignition timing initial advance....
Car has been repainted and of course.... NO LABLE!!!! :wow:
anyone have any ideas where I should put the mark?
