Date: 07/13/2018 02:21 pm
Date: 08/05/2018 01:58 pm
Date: 04/07/2021 06:12 pm
Date: 07/10/2016 10:17 am
Date: 01/20/2018 07:51 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Date: 02/05/2017 09:45 am
Date: 08/24/2018 02:50 pm
Date: 12/10/2017 01:14 pm
  • Online today: 502
  • Guests: 491
  • Total: 491
Turbo swap gas tank
Started by papintosquared, July 12, 2006, 06:56:52 PM
papintosquared
okay guys, that helps a lot thanks!
Father Son Duo with two 80' pintos
He IS talking about the EFI T/C swap. The stock Pinto tank with an inline pump, done.
papintosquared
but what about the feul injected TC's which is what we are using, should we use the TC tank and all of its stuff?
CHEAPRACER
My '74 uses a main and a return line stock in the tank as well as a vent line. I used a factory '84 Turbocoupe in-line fuel pump and it works perfect. The recall rear end protector makes a perfect mount but it's still a tight fit. Also use EFI high pressure fuel line & clamps on the pressure side for your connections.
73pintogeek
Hi,
Is there something wrong with the stock (existing) tank?
As far as I know there is no reason to change it, unless it`s bad or you want to go with a fuel cell...or are you looking for a larger capacity tank? Have fun with the Turbo-swap... ;D
Rex
A bad day workin` on my Pinto is better than a good day at work!
papintosquared
I have a quick question
we are currently doing a turbo swap from an 88' thunderbird TC to an 80 pinto. but what gas tanks would fit it? we were gonna pull one out of a mustang but we werent sure, so if anyone could give us a list or the specs on a gas tank it would help. Thanks
Dhilton
