Date: 09/15/2019 08:30 pm
Date: 09/10/2018 10:41 pm
Date: 07/11/2023 11:39 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Date: 08/01/2023 06:53 pm
  • Online today: 1,972
  • Users: 1
  • Guests: 115
  • Total: 116
  • cbdpxp
Steering linkage / "Rag Joint" Repair Info
Started by 77turbopinto, June 27, 2006, 06:24:18 AM
pintoman2.0
I acquired a piece of heavy conveyor belt, rubber reinforced with steel mesh. I use it for rag joints, chin spoilers, any number of things. The last rag joint I made has about 50,000 on it and it still looks like the day I put it in.
I think the main reason the original ones fail is because people spill brake fluid on them.
P
Jinxter
I've had my spare Steering Coupling Disc on hand for quite a while now, it is #31005 from the Help! section (Dorman 705-061).  It is for "various Ford vehicles 1974 and up" (not Chrysler/Universal) and fits well. It is just a TAD on the large side when it comes to the hole spacing, but I was able to install it without dis-assembling half the car. I just reached down with the wrenches and changed it from above. Took all of 30 minutes - it was quite warm out and I really didn't want to be under the hood, so I'd say it was all good!
This is the second time I've changed it on this car, I believe the last one was the #31000.
Time to get another spare!!
Beat it to fit, paint it to match...
bobscat
Just thought I would stop in and reinforce the earlier statement about the ragjoint in the HELP dept.  I bought the one ending in 000, and it fit perfectly, but you may have to come up with some bolts on your own.  Luckily for me, mine had already been replaced before, and I was able to reuse the stuff that was already there, but in looking at the stuff included in the kit, I am not sure that it provided all the necessary hardware.
Get two of each and return the ones you don't need?
I need to do this on my 79. The nearest napa is an hour away. I know that the "HELP!" section in oreillys/autozone has one that will work but there are a couple there and im not sure which one i need. Does anyone have this part number or should i just pull it off and take it apart and go get one then? I can do that but id rather go get the part before hand so i have it ready to go when i get everything all apart. Think my 74 needs one too so i might as well get both.
Starliner
Yep Thanks....   I am lucky my two Pintos are low mileage and don't need them now.  But I usually drive my beaters to 160,000 miles and I am sure this will need to be done in the future.    Thanks for the great information.
Select, right click, copy, paste, save !!!!
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
Bill gets a one up for his post . Thanks Bill
junkyard dog
  :text_yb_warning:
In the General Help section there are a bunch of threads about this topic: Pinto Steering, Steering shaft, Steering Rag Joint Pics?, Rag joint help, A little help is needed, Steering joint help please!!, Steering wheel slack? (and maybe a few others too).
Due to the number of people requesting information on Pinto steering "rag joints", I thought I would post some info here. Please note these are not "instructions", just general information on this topic.
Ford used a disc made of plastic in the joint, and it seems that a good number of them fail (if not all). There is a safety bracket assy. on the joint to keep steering control WHEN the disc fails, it makes the steering very sloppy and noisy, but you will have steering control at least for a while. When in use (failed disc), the safety bracket has metal to metal contact on the shaft, it WILL wear and possibly fail at some point too, leaving the car with NO steering; this is why it is CRITICAL to replace the disc.
The disc can fail just from age, improper maintenance, heat, poor road conditions, or from a crash. If the joint has been changed with a rubber disc it can fail too from being oil soaked, improper installation, or the reasons mentioned for the stock disc.
I have found the best way to change the joint is to remove the shaft/joint from the car. Also, I have found that the pins that hold the plastic disc are not threaded, but are rivets and need to be drilled out. This is not to say that all of them are like that, but on the ones I have worked on anyway.
After looking at a bunch of parts stores, I have not found a direct replacement part # for a Pinto, but NAPA has a kit that is NOT for a Pinto, and the disc fits. Napa # 630-1012. It has been a while, but from what I remember you might need to buy a bolt or two and some washers to install the disc from this kit. Use LOCK NUTS (non-plastic), insure that the lock feature is engaged, ALWAYS re-install the safety bracket, and do not over tighten the bolts and crush the rubber.
I have never checked to see if Ford still has them available, but I would assume IF they did it would be an assy. with the shaft (and VERY expensive).
One time I made a disc from the side wall of an old tire (IMHO, if you can remove the shaft and install a new disc, you CAN make a disc too). The new ones look like tire side walls anyway, and I just installed it with bolts and LOCK NUTS. Again, I was careful not to crush the rubber disc, and I reccamend some sort of spacer on the bolts too if you have them (or the correct shank length on the bolts).
From time to time I see NOS rag joints and shafts on ebay from $30. to $100., but with the age that they are, they might be short lived.
Steering is very critical for driving safety, if you are not 100% comfortable with doing work to this system, have your car repaired by a licensed automotive repair facility.
ADDED 6 Feb 07: I picked up a rag joint repair from NAPA, part # 630-1008, and it worked fine. This one is listed for Pintos from 71 to 75 in the NAPA book.
