1980 hood needed
Date: 04/23/2020 10:41 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 05/28/2017 03:20 pm
Date: 03/18/2020 01:30 am
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
Date: 01/30/2017 01:48 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 06/25/2021 12:59 am
74 & Up Parts
Date: 01/20/2021 03:22 pm
  • Online today: 535
  • Guests: 382
  • Total: 382
Wheel Lug Pattern?
Started by 72Wagon, June 22, 2006, 08:00:54 PM
Yes.
Any year Maverick will do for a donor, they all have the same axle assy., but the gears might be different from car to car. The Mav. rear assy. is .5" NARROWER than a Pinto one. These axle assy.s are not a direct bolt in in the later Pintos, and will take a little cutting of the perches, but no welding needed for the install. I have never worked on pre 74 Pintos, so I have no further info for you.
Check out the FAQ section too.
72Wagon
 Thanks, do they use the same stud size as the 4 lug?
1972 Wagon
5 on 4.5 is the common ford passenger car pattern.
Just find a 8" rear axel from a 1972 Maverick.
You can use the 5 lug rotors from Heidts Street Rod with a little machining and grinding.
Easy if you have a machine shop that will do what you ask them to...
From pintony
72Wagon
 What 5 lug wheel pattern and stud size when converting from 4 x 4 1/4?  Thinking of converting to 5 for better wheel selection.
1972 Wagon
