pinto wagon parts
Date: 12/19/2019 01:43 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 08/05/2018 01:58 pm
Date: 09/12/2018 04:07 pm
Date: 08/08/2018 12:26 pm
Oddsnends
Date: 12/20/2016 10:52 am
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
74 hood
Date: 07/03/2017 03:46 pm
  • Online today: 261
  • Guests: 197
  • Total: 197
disk brakes
Started by cole559, June 22, 2006, 01:53:49 PM
Quote from: Bipper on June 24, 2006, 05:33:43 PM
Disc brake set up from 71-73 will swap to the 71.
"1973 Pinto ONLY"
NOTICE If you are doing a Junk Yard swap be sure to get the tie rod ends from a 73 Pinto too as they are bigger than the 71-72 Pinto tie-rods.
The 73 spindles have a bigger arm and bigger hole for the tie-rod than the early 71-72 Pinto.
Not sure about the rack&pinnion "THREADS" though... BIGGER or smaller??????
wagonmaster
I believe Wilwood also has a conversion kit for the '71-'73 that would have 5-lug pattern.
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
Bipper
71 Sedan, stock
72 Pangra
73 Runabout, 2L turbo propane
cole559
What year pinto has disk brakes on it that will swap over to a 71 drum brake sedan.Better yet is there a 5 lug car that will swap over? I have a drum brake setup and need assistance in getting a setu-p for disk.
