ford pinto door panels
Date: 03/20/2022 07:51 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 03/23/2018 09:23 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 03/27/2017 10:07 pm
Date: 01/10/2022 03:41 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 02/27/2017 10:10 pm
  • Online today: 261
  • Guests: 251
  • Total: 251
how does OHC work?
Started by renton481, June 14, 2006, 05:54:54 AM
renton481
thanks for the pic.
I think I've got it figured now.
DragonWagon
In the process of a rebuild and am taking pic's as I go... let's see if I can figure out this image attachment thingy...
1976 mpg Wagon. The start of it all.
1977 Cruising Wagon, to be turboed.
1979 glass hatchback. No motor atm.
1980 wagon parts car.
dirt track demon
There is a check ball and spring inside the lifters, oil pressure causes them to "pump up", which allows a little dampening of the force used to open the valve kinda like a shock on your cars suspension, eliminating the need for adjusters like you would see on a solid lifter motor.  the fluid action of the oil in the lifter is where the term "hydraulic" comes in.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
The hyd. "lifters" put pressure on the followers to keep them from claking and falling out.
renton481
thanks Harry, that helps a lot.
further question:  does the lifter actually lift?  or just sit there.
and if it's hydraulic, why?
bigh4th
Its a very crude drawing, but it should at least give you an idea of how an OHC engine works:
-Harry
The easy way to describe it in detail: pull off your valve cover.
The hard way: stationary hyd. adjusters (lifters) on one side, with followers under the cam, and the valves on the other side.
renton481
I was looking over my chiltons -- can't really make out how the overhead cam in the 2.3 operates the valves.  The drawing isn't all that good, it's a bit smudgy.
Can someone explain how the OHC operates the valves?
