Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 11/11/2019 04:49 pm
Date: 02/22/2017 01:58 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Date: 05/13/2021 05:29 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 02/18/2017 04:47 pm
  • Online today: 1,258
  • Guests: 1195
  • Total: 1195
T-Bird wheels on Pinto
Started by Late Models Best, April 28, 2006, 08:14:32 PM
pintowgn73
I had a set of mustang 10 holes on my 73 wagon with 225/60r15's on them, the tires rubbed at full lock either way, but not at any other time. the tires were too tall, I think a set of 225/50's would have been much better.
wagonmaster
Generally the T-bird and Mustang wheels will require a 1/4" spacer to clear the upper control arm. Even with the spacer, there may still be clearance issues with the control arm at full lock on the steering. These wheels run around a 5" back spacing, which is substantially more of an negative offset than the stock wheels have. I ran the 15x7 steel wheels used on the '86 Mustang Police Specials using the 1/4" spacers on a '77 wagon I had for a couple of years. Being steel, these are thinner than the alloy wheels and they were still close on the control arms. I ran 205/50-15 tires and had one spot where they would rub the inner fender shield at full lock. These tires are 23.1" tall, so a tire this tall, but slightly narrower, would probably clear everything without any problems.
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
rbohm
i agree, i think the 70's are a bit too tall and you might have some rubbing issues.
64 falcon
66 mustang
82 fairmont
a man's fate is a man's fate
and life is but an illusion
fordsix.com admin
I am currently running 205-50-15's on my 73, a little different, but these same wheels rubbed a little on my 79 wagon.  I think you may be able to use the wheels, possibly with spacers, but I do not think the 70 series tires will work on the front.
Late Models Best
I have a 86 T-Bird Turbo coupe I'm parting out. I would like to use the 15 Aluminum wheels on my 80 Pinto wagon with 205/ 15"-70s tires  on them.  Does anyone know if this combo will work?  Is there enough clearance?
Tom D.
TJD
