Date: 04/06/2017 12:13 am
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 08/13/2021 10:39 am
Date: 04/28/2018 04:12 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Date: 06/12/2018 08:18 pm
  • Online today: 306
  • Guests: 210
  • Total: 210
2.8 ----> 2.9?
Started by BBfox, April 25, 2006, 12:47:09 AM
BBfox
yeah, good points on all of those
bigh4th
Unless you used the upper intake from a merkur (sp) 2.9, theres no way the hood would clear.  Plus if the 2.9's have stock heads, they're junk.  Let it get a little warmer than normal and they crack and piss coolant in the cylinders, usualy on cylinders 1 and 6 right between the valves.    If you put the world heads on one, you've got a decent engine if you can tollerate the lifter ticking from the crappy job ford did converting from the 2.8's solid lifters to the 2.9's hydraulic lifters.
The 4.0 ohv may clear the hood, but i've never looked at the intake on one.  Even then, its a whole lot of work for 160 hp, but she'll have a good ammount of torque.
The 4.0 ohc is good for 220 hp and if you want to pay for it, you can get a manifold to clear the hood, but it'll have to be from the ford stealership and you'll have to run the OBD 2 (1996 and up) system which will be a major PITA.
-Harry
BBfox
anyone put a 2.9 in a pinto, or some other v6, how about a 4.0 (that would be interesting)?.......................just curious
