Crane Cam
Date: 02/26/2018 07:50 am
Date: 08/03/2018 09:19 am
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
Date: 05/22/2018 01:54 pm
Date: 04/13/2017 04:56 am
Date: 04/21/2017 02:03 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Date: 11/08/2019 10:01 am
  • Online today: 367
  • Guests: 307
  • Total: 307
outter door handle sticks
Started by orangerunabout, December 02, 2003, 11:40:08 AM
Underdog76
Hey Leo, what can you tell me about choppin pintos?
Fast as lightning, strong as thunder
leothelyon
I strongly agree that you don't use a crowbar to remove the door panel. I found a "panel popper" for a very reasonable price, (couple of bucks) looks like a screwdiriver with a different tip. Make sure you take off the inside "door pulls" also make sure you put the plastic liner back on when your done. There will be two nuts holding the door handle on from the inside. Its a real simple process. Nothing hard at all. I've been a body man most my life if you need any help e-mail me and I'll walk you through it.
I know about the panel popper, i reccomended a crowbar ,because just about everyone has one. a clawhammer will do the same thing. all you've got to do is grab the clip so it pulls out of the door, not the panel ;D
Underdog76
Rather than using a crowbar there is a tool called a panel popper that is specificaly made for taking off panels. other than that it is not hard to replace. I have to do the same thing to my dads car.
orangerunabout
thanks for the help, ill probably go grab 2 from the yard, try to fix mine and if it deosnt work ill just swap em.
Check out the internets only Turbo Pinto forum
www.planetboost.com/pinto
the door panels come off after the handles and armrests (1screw in each handle 2 3/8 bolts in the armrest GENTLY pry up the chrome ring at the top of the armrest to expose the screw there) once those are off if you have a crowbar (no really trust me) use the flat end to find the clips that hold the panel on put the clip between the fork and GENTLY pry it up
the clips are just held in the panel which is fiberboard.
once you get inside, the door handle is held on by 2 nuts.
Mine used to stick pretty badly too. i was able to use WD40 inside the door to free it up. once it was free i sprayed all the pivots with white lithium grease
orangerunabout
tried to WD40 it, thanks though
any idea how to remove the handle or door panel?
I may sound kinda dumb if you've done this already, but, have you tried spraying wd40 into the mechanism? If so ignore the dummy here LOL
if the wd40 frees it up; find a good lithium spray grease to spray into the handle, and the latch on the door
orangerunabout
then i open the door, the thing on the outside stays stuck in. it sticks really bad and i have to hit it hard to get it to open so i can shut the door. i have seen a few im the yeard thatwork perfectly but have o idead how to remove them or the door panel on these cars. also, is there an easy fix or should i just swap them?
