Date: 05/13/2021 05:29 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Mirror
Date: 04/15/2020 01:42 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
Date: 04/30/2023 04:31 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
Date: 08/24/2018 02:50 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
  • Online today: 905
  • Guests: 552
  • Total: 552
early Pinto/ mustang II control arm interchange
Started by dragpinto, April 18, 2006, 07:13:10 PM
dragpinto
I ended up just buying a complete wilwood kit off of ebay instead. I'm selling the other complete kit if anyone is interested. Thanks for all the help.
earthquake
If front discs you want early pintos  had them also, and are easy to do.I have a 73 with all the parts including the proportioning valve if your interested
I have seen a bunch of posts that all the later pinto suspention will fit on the early ones IF you use ALL the parts from the later car. I have never owned an early pinto, so I can't say for sure, butI have seen posts.
Quote from: dragpinto on April 18, 2006, 07:53:48 PM
thanks for the help. ??? You know anyone that needs 2" drop spindles/brakes? Ha Ha
iF YOU JUST WANT FRONT DISC BRAKES?
wILWOOD MAKES A LIGHT DUTY SET FOR DRAG RACING AND A MED DUTY SET FOR STREET DRIVING.
fROM pINTONY
dragpinto
WOW Dude you are really screwed!
There are guys out there that say it can be done but I would not try it.
Your only choice now is to cut the early cross member off and weld in a later Mii style cross member.
That is what I did on my 73.
dragpinto
I have a 72 Pinto Drag car that has drum brakes on the front. I bought the Mustang II front spindle/disc brake conversion with 2" drop spindles off of e-bay (fatrodders). I've now found that the spindles are 1" taller. Would bolting on the mustang II upper and lower control arms solve my dilema? Will they bolt onto the frame in the same locations where the pinto's are?  I already have new tie rod ends(mustang II) and a new steering rack(early pinto) that I'll machine and weld adapters because of the different thread size. Any help would be greatly appreciated.
        Thanks,
        Lee
